Escort Turbo
Old Mar 16, 2005 | 05:56 PM
l5tuy's Avatar
l5tuy
Default Escort Turbo
Im looking for some ideas on what could be wrong with my BLOODY car,
It is not idling at all, the thing just dies. Iv tried replacing the air lines as i thought there was a leek due to hissing noise, however no joy and still getting a hissing from the carb.
Its really starting to annoy me and could end in divorce (with the car and wife).
Any ideas would be verry much appreciated.
Thanks
Old Mar 16, 2005 | 05:57 PM
Exeter J's Avatar
Exeter J
Is this an RST (as indicated by your title) ??
Old Mar 16, 2005 | 05:59 PM
Billabong's Avatar
Billabong
As per Exeter J and sounds like an air leak on boost pipes, or a leaky dump valve if fitted.
Old Mar 16, 2005 | 06:00 PM
Exeter J's Avatar
Exeter J
Originally Posted by Bill
a leaky dump valve
Was my first thoughts - before seeing 'carb', also
Old Mar 16, 2005 | 06:09 PM
l5tuy's Avatar
l5tuy
There was a dump valve however i have taken this off.
Also i don't know the proper name for the fuel air mixing chamber i just assumed it was still called a carb. There are two airlines comming out off it anyway one to the rocker cover one to the bulkhead area.
Old Mar 16, 2005 | 06:10 PM
rs_daz's Avatar
rs_daz
have you pluged the hole for the d/v off well?
Old Mar 16, 2005 | 06:13 PM
Exeter J's Avatar
Exeter J
The chamber which is part of the inlet manifold is called the 'Pleneum' and as your car has 4 point fuel injection there is no carb.
Anyway has the small vacuum pipe from the other side of the dump valve been blocked off aswell as the large one where the DV sat?
Billabong's Avatar
Billabong
No worries - inlet plenum and throttle body are the injection equivelents to a carb'.
Old Mar 16, 2005 | 07:45 PM
l5tuy's Avatar
l5tuy
Will the d/v still have an effect even though i have dislocated the pip from the top of it
Old Mar 16, 2005 | 08:16 PM
Stoo's Avatar
Stoo
As long as you have blocked off the pipes at each end of the dump valve(So there are no air leaks)then yes,it is OK to remove it.
Vincereese
Jun 1, 2023 09:14 AM
Matt Baxter
Sep 16, 2015 08:30 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
druidgetafix
Aug 15, 2015 10:22 AM
