Polyurethane or Standard? TCA to ARB Bushes
Just received my new adjustable TCA's, compbrake ones with the cosworth size ball joint, and they have come with original rubber bushes where the ARB passes through. Is their much to be gained from replacing these with decent quality poly bushes?
I Guess the answer is yes, as i have group a style concentric top mounts and rose jointed inner TCA mountings, so this will be the only point on the front end (apart from the ARB to shell mounts) where movement can come from.
to be honest i am not always a fan of poly bushes, it depends on the application.
in most cases i think people see such a big improvement because they have replaced old knackered bushes with new 'uprated' ones. if they fitted new standard bushes they would see an improvement too.
Gary Krishna
Mark V8
Sep 13, 2015 09:34 AM
