Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Mk1 Focus front fog light removal
Old May 21, 2013 | 09:17 AM
Thrustyjust's Avatar
Thrustyjust
Default Mk1 Focus front fog light removal
Tried to take the ones out of my daughters car to clean them out, as going white inside. Undid the clip and unplugged the cable, but it gets jammed in the grill with the aim adjuster. Is there a knack, as the poor haynes manual just says remove it . Do i need to take the lower grill out and if so, how? Cheers
Old May 24, 2013 | 11:31 AM
Thrustyjust
Managed to sort this . You need to pull the lower grill out to give you space and then on the outside edge of the light is a knuckle pivot for the aim adjuster to work and you push it towards the grill to un locate it. Then it should come out. Bloody fiddly job just to clean the lenses out. Look nice and silver and clean now. Now I know when i see cars with broken ones, why they dont want to change them !!
Old May 24, 2013 | 05:25 PM
Lee-87's Avatar
Lee-87
I was going to comment past night but realised to do mine Is different as its the face lift model
Old May 29, 2013 | 04:16 PM
Thrustyjust
No worries Lee. They were a git to get to, with the a/c pipes behind the drivers side and the horns bolted to the passenger side. Almost need double jointed wrists. Now got a sticky starter motor to contend with..........aarrggghhhhhhh
Escortdriver1
Aug 13, 2015 05:55 PM
track.focus'd
Aug 12, 2015 05:53 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
sridgett
15
Aug 3, 2015 07:26 PM
