Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Fiesta MK6 cooling fan problem
Old May 18, 2013 | 03:40 PM
kemot001's Avatar
kemot001
Default Fiesta MK6 cooling fan problem
Hi for all!
I had a trouble with my motor cooling in my Fiesta MK6 1,4 16V 2004 with AC!
It happened, then the fan wheel was jammed, and the motor went broken. Now the motor is changed, but in the car doesn't work.
My questions are:
1. Which is the fuse of this motor?
2. How can I try? Is it a good solution, when I turn on the AC? I mean, when the AC is working, the cooling fan must, too!
3. How can I check the thermostat, where can I find?
4. Does somebody has a wiring diagram and a service manual for this car?
thanks before:
kemot
23
Sep 12, 2015 12:56 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
