Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
MK1 focus failed MOT on emissions
Old May 16, 2013 | 07:43 PM
CaptainAnswer's Avatar
CaptainAnswer
Default MK1 focus failed MOT on emissions
My focus has failed the MOT on emissions, results as below. It has had new plugs, leads and I've put redex through the system in the last few weeks. I fault code read the ECU but no codes were found, garage recommended the Lamda sensor, so I've ordered one for retest and put in a new air filter.
I noticed on the air intake one of the screws is missing, this was not the case last year, it looks like it has been cutaway at the last service, so I will try and find a bolt to go through there also before the test.
MK1 focus, 122k on the clock driven fairly hard and usually clock 150 miles a week. Oil, oil filter, plugs, air filter all changed last summer.
Any other recommendations would be fantastic
First fast idle: 2750-3150 rpm (sheet states engine speed: not checked)
CO (<0.3%) result 0.46% - FAIL
HC (<200ppm) result 52ppm - PASS
Lambda (0.950-1.090) result 1.007 - PASS
Second fast idle: 2750-3150 rpm (sheet states engine speed: not checked)
CO (<0.3%) result 0.39% - FAIL
HC (<200ppm) result 29ppm - PASS
Lambda (0.950-1.090) result 1.004 - PASS
Natural idle test - PASS
CO: (< 0.5%) result 0.5%
Old May 20, 2013 | 05:59 PM
xenton's Avatar
xenton
Enthusiastic Novice
Did you take it for a good long run before the MOT? You weren't a million miles over and it was coming down by the second test. I think if you take it for a long run so it gets hot and is still warm by the time they test it, that should be enough to pass.
If you do lot of short journeys this won't help things. Take it for a good long motorway blast, and when it's properly warm make sure you open it up. Then straight in for the retest.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
natehall
Sep 8, 2015 05:13 AM
Sep 3, 2015 10:49 AM
