Mk3 2.5 Ghia X
Might be going to have a look at one of these tomorrow. Wondered if anyone could give me any pointers please? Not really famililar with the mk3's. Any adviced is much appreciated, thanks!
what do you want to know?
make sure all the electrics work, the ghis x is top of the range so should have all the bells and whistles other than xenons, but if they are fitted make sure they self level, it's a dealer fix if you disconnect the battery so you have been warned and can haggle on that, it's about an hours labour
make sure the cruise control works
make sure it pulls up in a straight line
and it doesn't feel weird in a stright line or round corners
clunking from the front end is normally arb drop links, £55 each from ford a fiver from ebay, the ford ones last much longer
it should have electric seats with hot and cold options
make sure the climate control works as it should too and not just the air con, stick it on auto and drop it right to the lowest setting, 17 degrees and then lo to make sure it works
the middle rear seat belt will stick, it's an easy fix but if it's not it's a totaly seat strip down, again, fairly easy if you know what you are doing but not if you don't
alloys can corrode and the lacquer can lift up, use it as a haggling point as well
make sure it's got the chrome bits on the door handles and grille is it's a facelift, not so sure about the rear lights and boot handle
should come with power fold mirrors so check them too
the only issues is making sure it's a proper facelift with the different centre console
other than that, you've got different things to check for if it's auto or manual and if it's saloon, hatch, estate
Cheers lads. Unfortunately it sold before I'd got the chance to have a look. Bit gutted as I didn't know how spec'd up they were and it was dirt cheap. I'll be quicker next time!
mk3ste
Oct 17, 2021 10:09 AM
Steve Escos
Oct 1, 2015 06:57 AM
