"Class not registered"
Old Mar 16, 2005 | 10:04 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default "Class not registered"
Comes up when trying to open a vid file.
What that mean?
Old Mar 16, 2005 | 10:06 AM
Physio's Avatar
Physio
Means the class is not registered
Old Mar 16, 2005 | 10:09 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
I thought as much, i can sleep easy now im sure
Old Mar 16, 2005 | 10:13 AM
Physio's Avatar
Physio
Glad i could help mate
Old Mar 16, 2005 | 10:16 AM
Crazy Canuck's Avatar
Crazy Canuck
It likely means that there is a DLL file that is not registered in your windows registry.
Did a quick check and found the following. Can give no guarantees of its outcome. Personally I would leave well enough alone unless you absolutely need to view the file:-
http://www.hitsquad.com/smm/programs...ages/3096.html
In Reply to: "CLASS NOT REGISTERED" posted by rudy on March 26, 2002 at 12:06:54:
Win Media Player 9 fails to load the libraries necessary to activate many streaming audio and video windows. The libraries are referred to as DLL files and they reside in your windows/system directory.
The solution is to:
1. Download Win Media Player 7.1 from the MS
site;
2. Disconnect from your internet connection;
3. Close all other programs;
4. Activate the 7.1 setup program;
5. Select "reinstall all components";
6. The program will advise that setup has failed
(its looking for files over the internet),
then force you to reboot;
7. When you reboot, 7.1 setup will begin
updating your windows settings. Actually,
it will be loading and registering the
libraries you need to open streaming windows;
8. WinMedPlyr 9 will remain intact; open and use
it as normal. You may find need for various
additional codecs. One package resides in
the MS download site, the others are on
divx.com or moviecodec.com.
DAN@ADRIAN FLUX
Insurance
15
Jun 30, 2018 09:00 PM
fuzzy
21
Feb 15, 2016 10:26 PM
jonnyenglish
Sep 21, 2015 07:31 AM
cossiestu
Sep 19, 2015 05:19 AM
