Mondeo Alarm Keeps Going Off
Old May 9, 2013 | 06:19 PM
deathrider666's Avatar
deathrider666
Damn Cars
Default Mondeo Alarm Keeps Going Off
The alarm on my 2002 Mondeo has started going off on its own, I'm wondering if when I slammed the driver door shut in anger the other day had something to do with it?
Is there ansensor switches on the driver door?
Old May 9, 2013 | 06:26 PM
deathrider666
Damn Cars
Just noticed it looks like some kind of switch on the pillar located on where the latch catches, could this be it?
Old May 9, 2013 | 06:29 PM
dug112y's Avatar
dug112y
passionford pro
yes. open bonnet.press bonnet switch until horn beeps then open each door individually ...you should hear a beep....then lock and unlock drivers and passengers doors with key(not remote) beep should be heard on lock and unlock action aswell
Old Jun 30, 2013 | 04:49 PM
deathrider666
Damn Cars
I think it's the switch under the bonnet playing up, it's the one by the latch yes?
Old Jul 22, 2013 | 11:04 AM
daviddunlop83's Avatar
daviddunlop83
My old mondeo had a faulty bonnet switch, I just cut the wires and joined them together.
Old Jul 22, 2013 | 11:10 AM
daviddunlop83
You can enter into a test mode that chirps when you activate each door, bonnet and boot etc so it lets you know each sensor is working
Old Jul 22, 2013 | 11:35 AM
RichieST's Avatar
RichieST
Very common on the focus for the bonnet catch to play up. It happened on mine a few weeks ago, I noticed also when driving every now and then it would flash up bonnet open on the dash. I just unplugged it and bridged the wires in the plug together with a small bit of wire.
Old Jul 22, 2013 | 05:05 PM
GVK.'s Avatar
GVK.
Just to clarify, you press and release, press and release until the horn sounds to say it's in test mode, not just keep it pressed.
But yes, nine times out of ten it's the bonnet switch playing up.
mark94
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
