few cosworth parts for sale
Old May 6, 2013 | 01:43 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Default few cosworth parts for sale
Group a spec r dump valve in black with the stainless braided hose this is 250 pounds to buy new! one allen key bolt missing from top also has push on hose fitting at the top as i needed the screw one for my car.
So to use the braided hose in the pic you will need to order a m10-1mm to an3 fitting from torques
£150 posted
Stainless t piece for dump valve 60mm
£20 posted
Spec r turbo pre rad this was on my car bolted to the top of my rad has a 8mm in and out also a bleed screw on the side! I dont think its made for a cosworth but worked fine on my car for many years only took off as my new intercooler came with a new pre rad
£50 posted
Turbo water pipe fittings in stainless bango bolt type 10mm tails
£10 posted
RS500 style intercooler no idea what make its a 60mm core one with a 60mm inlet and outlet! The out
let pipe was modded so it would mate with my hart manifold a little better so may need modding again to use on a car with the normal type manifolds! Also has a small tapped hole in the outlet that a water injetion jet screwed into that will need plugging or welding up also one on the other side thats already plugged
£60 pounds will have to check on posting so pick up from basingstoke would be better
Old May 6, 2013 | 01:52 PM
ajamesc's Avatar
ajamesc
Also have a genuine saff fuel tank with the plastic swirl pot (the one that works un like the shit copy tanks) £60
And a water injection system that i no longer need as i have a spec r intercooler!
This syten has the pump a stainless water tank these mounted in the boot on the back of the rear seats. Also a water hose that runs to the intercooler the jet and the wiring as it was in my own car (saff)
The system was activated via a relay that was triggered from my sm4 ecu this is still on my car at the mo so i will get some pics up and remove it this week £80
Old May 6, 2013 | 04:03 PM
Sonic Boom's Avatar
Sonic Boom
pm'd
Rich
Old May 6, 2013 | 04:44 PM
William MK2 Cosworth's Avatar
Can you please put a picture of the water system
Thanks
William
Old May 10, 2013 | 03:17 PM
ajamesc's Avatar
ajamesc
Looks like I've sold the water injection system to sonic
Is no one interested in the other bits before I eBay them I was shore someone would wont a nice new black group a dump valve there loads of money new
Old May 11, 2013 | 08:09 PM
ajamesc's Avatar
ajamesc
sold the pre rad and water injection kit
Old May 16, 2013 | 12:43 PM
ajamesc's Avatar
ajamesc
Will take 110 posted for the dump valve. Can also post the intercooler for a price
Old May 16, 2013 | 12:59 PM
andremarca's Avatar
andremarca
Can you post the intercooler to Portugal? Interested in it. parcel2go gives me a quote of about 20£
Thanks
Old May 16, 2013 | 01:03 PM
ajamesc's Avatar
ajamesc
Thanks
ill send it any wear if you pay mate! But 20 pounds sounds cheep I had a quote of 50 to send it to Ireland send me a link to the post company and your address and ill get a quote
Old May 16, 2013 | 02:30 PM
rob_manu's Avatar
rob_manu
hi. could you drop me a text. as I'd like to buy the intercooler. 07850594683 cheers Rob
Old May 16, 2013 | 06:42 PM
andremarca's Avatar
andremarca
Hehehehe, Thanks
We'll sort something out for sure. Sent you a PM
Old May 16, 2013 | 07:26 PM
Sonic Boom's Avatar
Sonic Boom
Water Injection turned up the other day spot on cheers mate.
Rich
Old May 16, 2013 | 07:32 PM
ajamesc's Avatar
ajamesc
Rich
cool let me know if you have any probs but you shouldn't its straight forward to fit and I labeled up the loom
bigryrs
Mar 28, 2016 09:11 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
