Misfire on Escort Cosworth - Help!!
Old May 6, 2013 | 10:37 AM
bigdel's Avatar
bigdel
Default Misfire on Escort Cosworth - Help!!
Hi all,
My neighbour has a 1996 Escort Cosworth which has just developed a nasty misfire when it coems on boost.
The misfire is just about detectable under normal driving conditions and can be felt as a slight hesitation, but as soon as it comes on boost the hesitation gets even worse and the whole car starts to vibrate. Boost seems to build very slowly but the increase in boost pressure doesn't bring with it an increase in power.
He was most pissed off earlier when he couldn't keep up with a Citroen DS3
The car's completely standard, and only has 15k on the clock. It has been standing in the garage since about xmas without being started, before then it was running ok.
Any ideas?
Oh,forgot to say we've changed the plugs (standard Ford) and that hasn't helped
Any suggestions as to the likely cause are welcome
Old May 6, 2013 | 11:54 AM
bigdel's Avatar
bigdel
Sorted!!
Fitted a second new set of plugs, and it goes like a train now!
First set will be going back to Ford!
Old May 6, 2013 | 04:40 PM
William MK2 Cosworth's Avatar
Not sure if it helps, but do the escos' need their plugs gaping like on the sierra's?
Old May 6, 2013 | 06:14 PM
bigdel's Avatar
bigdel
gaps checked before fitting (didn't need any adjustment from the box), we reckon 1 of the 4 was duff. He had a whole box of new ones, so just picked another 4 and fitted them.
Old May 6, 2013 | 06:39 PM
adam151082's Avatar
adam151082
Sounds like the gap was to big to me.
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
