RS 5tu S2 RS Turbo Project, BBS E50 content :)
i like the wheels i wasnt sure at first and was thinking of getting some compomotives but wanted to be alittle different so think ill be keeping them on for now.
These turned up today,
My plan is to strip my engine this weekend and get the block honed and crank checked
Then I'll buy all the bearings ect once I know everything is ok.
I plan on getting most of my bits from a EFI xr3i i have, loom, head, inlet, flywheel ect ect the ECU will PnP into the 3i loom most of the build time will be checking and cleaning bits before putting it all back in.
Engine wise ive come to a bit of a stop, unless i can get a 2nd hand decent forged engine im just going to rebuild my 1600 as i wasnt looking for anything special power wise around 250 would have done but dont fancy spending 1k+ on just a bottom end at the moment as i am not sure if thats what i want from the car i would rarther have a nice clean car i can use and less power.
i cleaned my pistons and rods up so they could be checked for cracks and there fine amazing how clean they come up with the right equipment.
sounds like a cool project mate keep the updates coming
the williams steel rods seem good too mate, simsytall on here ran them at 24/25psi on a stage 3 t3 and 5th injector with no problems
What power did simsytall make?
My next thing on my to do list is sort the battery tray out in the car as it needs a new one. Engine wise im just waiting on a bottom end really but carnt make my mind up at the moment but pretty sure im going to stick with CVH and got my head back from the machine shop today it was getting skimmed.
So far i have got as far as:
Ofam ecu
Ported and polished EFI head with bigger valves, bronze guides and double valve springs.
Cossie T3 rebuilt with 360 bearing
next few weeks
bottom end will be a fully rebuilt CVH with forged pistons and rods HD bearings and high preasure oil pump.
need to sort a cam and some injectors and then tidy and check my loom.
no idea what power i will end up with but i would be happy with a few less horse power and alittle more reliability
I've a set of focus rs mk1 injectors if any use to you, I live in blackpool too.
Ł20 if you want them.
be nice to see another rs turbo out and about in blackpool, I remember back in the day when it was a everyday site.
Thanks for the comments,
I should be in a position to take my engine to AMS for building in the next two weeks.
Ill feel better about it when it's just back on the ground rolling around and not on axel stands gathering dust.
What impedance do they run at out of interest?
Thx, its time at the moment thats the hold up i just done have any free with work and traveling.
Next on the slightly smaller "to do" list
Full polly bush set powder coated bits, and then sort a gearbox out and paint the engine bay also toying with the idea of putting in a different set or recaros i have from a Proton GTI but not sure yet, ill dig a picture out.
