Ford Puma Discuss the Ford Puma here!
abs/tc problems please help
Old Apr 30, 2013 | 04:59 PM
soapy1's Avatar
soapy1
Default abs/tc problems please help
Hi, when I do normal braking in my 2001 1.7 puma I get a grating noise from the brakes as if the abs or traction control kicks in (same noise when you try to pull away in snow) but there are no warning lights showing, the abs/tc lights come on then go off when engine is started which is normal and the self test at 12 mph seems to be normal and ok so this has got me stumped, recently had new discs and pads fitted about a fortnight ago also this only happens when the car is coming to a complete stop as if the wheels have stopped but the engine is still trying to drive, any idea's please help.
Old May 2, 2013 | 07:14 AM
melinamotor's Avatar
melinamotor
Farpylee
ABS sensor or a knackered tone ring.
Old May 2, 2013 | 05:14 PM
soapy1's Avatar
soapy1
Hi, thanks I'm going to try a couple of new front sensors at the weekend to see if that cure's it.
Old May 3, 2013 | 07:06 AM
melinamotor
Farpylee
Are you sure its from the front end?
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
