Series 1 and series 2 rs turbo gear linkage the same?
Apr 25, 2013 | 05:32 PM
As above does anyone know if the series 1 and series 2 rs turbo gear linkages are the same?
Apr 26, 2013 | 06:59 AM
Don't think they are all the same, as some models had push down reverse?
Use a Puma linkage instead, cheap and makes a huge difference!
Apr 26, 2013 | 08:47 AM
exactly the same like above only difference is 1 is push down reverse other lift up reverse
Apr 26, 2013 | 06:31 PM
My RS is push down reverse as was my XR3i, but my low spec 1.3l 90 escort wasnt push down..... if it was it never needed to be pushed down. Never heard of lift up reverse on a mk3-4 escort though.
Apr 26, 2013 | 06:46 PM
no lift up reverse on a mk3/4
only lift up reverse linkages in fords are on mondeos ect
Apr 26, 2013 | 07:45 PM
ive got 30 odd breakers in yard and own 19 mk3 and mk4 myself some got push down some gota lift for reverse
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
marky_g
18
Aug 26, 2015 03:42 PM
IAN RS2k
Aug 18, 2015 07:51 PM
adriansaleem
Aug 1, 2015 09:28 PM
