2007 tdci problem......
Old Apr 22, 2013 | 04:32 AM
mercgrey's Avatar
mercgrey
Default 2007 tdci problem......
Hi guys ive recenly bought a 2007 mk3 tdci cheap as needing a new engine.. im just wondering if it could be a simple fix now after reading mixed storys?
Basically it starts but sound like it firing on 3 and is really noisy at low revs and chucks out some white smoke. Theres no fault codes or any old ones stored no fpashing glowplug lght and Apparently it had pump injectors and turbo checked and all fine.
So my question is has anyone else had this kind of problem before I rip the engine to bits? If its engine damage Could it be a broken rocker assembly? Or more likly pistons or rods?
Thanks for reading guys look forward to you theory's
Dave
Old Apr 22, 2013 | 01:39 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Dave
Could be one of a hundred things! How were the pump and injectors tested? As white smoke implies it's fuelling related.
Old Apr 23, 2013 | 06:05 AM
mercgrey's Avatar
mercgrey
Thats what im thinking now but it is noisy and runs on 3. The lad I brought it off says he has it tested in a garage for injectors pump and turbo but they told him it had a sticky valve and dodgy piston.......for the price I payed I dont mind changing engines but if its a simpler fix im happyer. Guess I need to buy the f super see what that tells me then prob buy a injector socket and whip the rocker cover off see hiw the carrier looks
mark94
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
talon1
Sep 15, 2015 10:27 AM
