ARP's...Big Thanks to Porkie.....
I got your parcel (ARP big end bolts) today thanks... (This is genuine to, came via ANC!!!)
Parcel from:-
PORKIE PIG
MARTIN HADLANDS ARSE
COCKSVILLE
SUCKYSUCK
NE1 4ABJ
The Instructions:-
1. Check part numbers on pack
2. Due to the nature of these bolts,it may require the rods to be re-drilled and some may require glue
3. We recommend using a hammer or a Phillips screwdriver to ensure correct installation
4. If you have no stretch gauge,you must follow this procedure:-
Torque to 440ft/lb
Undo
Repeat 736 times
5. Good Luck
6. Keep Note of all rod lengths...including your own
7. If you have any problems please call Mike Rainbird on 01580 550770
PassionFords Creator
