Zetec!!!! Whats your spec?
ENGINE
1798cc 16v ZETEC E,
8.6: 1 COMPRESSION,
0.5 OVERSIZE SKIMMED & POCKETED PISTONS,
WIRE RUNG BLOCK,
FLOWED HEAD,
3 ANGLE VALVE SEATS,
GENUINE FOCUS HEAD GASKET,
SERIES 2 T3 TURBO, -31 ACTUATOR,
BLEED VALVE,
PIPERCROSS CONE FILTER,
4.5” COLD FEED PIPE FOR TURBO,
FIESTA RST THROTTLE BODY,
FIESTA RST INJECTOR RAIL & FUEL PRESSURE REG,
REVERSED CHARGE CARRIER,
16V ESCORT ZETEC INLET MANIFOLD,
MODIFIED SAAB 9000 INTERCOOLER,
BAILEY OIL SEPERATOR,
SOLID BOOST PIPES,
MAGNEX STAINLESS EXHAUST,
JAP SPEC 4” STRAGHT CUT BACK BOX,
SAMCO HOSES,
FORGE GRP A DUMP VALVE,
BOSCH 701 BIEGE INJECTEORS,
ESCORT COSSIE IN TANK UPRATED FUEL PUMP,
XR2I IDLE AIR CONTROL VALVE,
OFAB FIESTA RS TURBO ENGINE MANAGEMENT,
1798cc 16v ZETEC E,
8.6: 1 COMPRESSION,
WIRE RUNG BLOCK,
FLOWED HEAD,
BLEED VALVE,
SOLID BOOST PIPES,
SAMCO HOSES,
Cheers Tony
Id love to see yours go, I've still to experience a well sorted 1800Zt.
Paul am sure if Ian & Ahmed are involved then its 'no secret its gona be a cracker'
Originally Posted by Paul Ripley
Its a secret
2.1 16V
recon head with stanartd cams
vaux calibra turbo pistons ( 7.4:1 CR )
modified conrods ,
ARP bolts
EFI flywheel
Escort 1.4 onlet with 2.0l throttle body
T3 / Focus RS hybrid exhaust manifold
T34 .48 housing 10/20psi
FRST management with 400cc injectors
044 pump
3" straight through exhaust
water injection
HUGE intercooler
stage 1 bernie box (CTS)
samcos , pace
blah blah
300 BHP +
over 260 @ wheels
modified conrods ,
ARP bolts
EFI flywheel
044 pump
water injection
HUGE intercooler
samcos , pace
blah blah
300 BHP +
over 260 @ wheels
mk3ste
Oct 17, 2021 10:09 AM
