sierra coswort project or
Here we have my project i reallly dont want to sell it but i got so much on at the mo and cant see me geting time to do it any time soon
all i seem to do is buy cossie' and never get time to do them ;( if it dont sell i dont really care i will just do it when i get some time i will put all the info from the ad whem i brought it ........ FORD SIERRA SAPPHIRE RS COSWORTH 2WD
Please Scroll Down For More Pictures
I've owned this car for almost 10 years, during that time it's covered less than 6,000 miles.
Unfortunately I've lost most of the invoices and*receipts*from all the work that has been done to the car over the last 10 years.
You can see in the pictures the history that comes with the car.
The*mileage*is 87,407
I run a HPI check on the car when I bought it in 2003 and it came back all clear. Report included with car.
Please note the car won't run in it's current state.
The following parts have been removed and don't come with the car:-
Turbo
Fuel Injectors
Map Sensor
Fuel Pump
ECU
Intercooler
Radiator
Alloys (comes with the wheel in the pictures)
Header Tank
Turbo Oil Feed Line
Cam Cover
Front Brakes (disks and calipers)
Ignition Coil
Air Box
Parts that come with the car but not fitted :-
Standard Radiator
Standard Front Brake Calipers With Good Pads
Standard Rear Lights
2WD Inlet Manifold and Elbow
Replacement Rear Spoiler
A Box with Various Parts inc a Standard Header Tank (Pictured)
Drivers Side A Pillar Trim
The standard turbo damper mounting casing on the head has been removed, pictured below.
Please note the engine has a bad bottom end knock and will need a complete rebuild.
The car comes with the following item still fitted :-
Full*Stainless Steel*Exhaust System (This has been modified and comes with a v-band flange, not the standard cosworth part)
Up Rated Dampers With Avo Springs (Springs only fitted a few years ago)
AP 6 Paddle Clutch Plate With Standard Cover (Covered Less Than 1,500 Miles)
Fuel Pump Re-Wire Kit Fitted
Various Blue Silicone Hoses
Toad Ai606 Alarm and*Immobiliser*With Remote Window Closure
One of the sills has been welded about 5 years ago.
Car Passed MOT last time, Currently Has No MOT and is SORN. Here is the link from when i g
Bodywork is in reasonable*condition, there are marks, scratches and blemished in the paint, most are pictured.
Turbo
Fuel Injectors
Map Sensor
Fuel Pump
ECU
Intercooler
Radiator
Header Tank
Turbo Oil Feed Line
Cam Cover
Ignition Coil
Air Box
Standard Radiator
Here is the link from when i got it http://www.ebay.co.uk/itm/2211910480...84.m1439.l2649 the engine is out now and the bottom end is in bit i have it all still tho i all so have the ecu and fuel pump and coil
nico12
Dec 31, 2015 04:42 PM
