Ford KA Discuss your Ford KA here!
indicators not working
Old Apr 8, 2013 | 05:14 PM
Shapeshifter's Avatar
Shapeshifter
Default indicators not working
At first it would stop working at times now it does not work at all. please help! i have no idea where the fuse box is so can't check the fuses. I also don't know where to finf the flikker unit. Please i'm a woman and need some good advice from people that knows. thank you
Old Apr 8, 2013 | 05:32 PM
mk2 cossie's Avatar
mk2 cossie
have you tried working the hazard switch?
i get several cars in at work with indicators not working, but the hazards do. Usually give that a working and a bit of electrical spray gets the indicators working as it cleans up the contacts in the switch
Old Apr 8, 2013 | 06:34 PM
Shapeshifter
Question
The hazards don't work either. Tonight when i came home the dashboard light was also not working. That is working now. I located the fuse box and all the fuses are in order. The indicater unit< is that one of the boxes located on the far right inside the bonnet? right against the body.
Old Apr 8, 2013 | 07:01 PM
Cossy Mike's Avatar
Cossy Mike
Is the flasher unit not under the steering column?
Old Apr 9, 2013 | 06:05 AM
Shapeshifter
I looked there but don't see anything other than the bonnet lever. And there's nothing i see that can be opened.
Old Apr 9, 2013 | 04:09 PM
Shapeshifter
Finally found the relays. They are all behind the fuse box. The user manual only numbers the fuses 1-22 but the relays are not numbered. There are about 6 or more ralays. i can't find anywhere that tells me which is which and the spare parts shop wants a sample. what to do.... i'll take a wild guess and say the red one is the one because that's how i feel. anyone that has the answer, please share with me.
thanks.
Old Apr 9, 2013 | 04:17 PM
mk2 cossie's Avatar
mk2 cossie
not sure on all of them, but the relay is usually on the stalks behind the cowling on the fiesta/ka
Vincereese
Sep 5, 2015 10:46 PM
RIB1122
Aug 12, 2015 08:51 PM
dlwarrior
Aug 5, 2015 10:19 AM
