RST opinions........
Old Mar 14, 2005 | 08:17 PM
D200RST's Avatar
D200RST
Default RST opinions........
Bought this and havent had it down the rolling road..... here is a pic of the engine bay and a list of mods that i know of. Ive been quoted by the guy i bought it off thats it around 200bhp. that seems a bit high to me though although its a handful to drive!
Mongoose 2.5, piper 285 cam, pipercross ind kit, fully rebuilt with triple angle valves (is that right?!?), group A head gasket, hybrid turbo, Pace intercooler (50% bigger), uprated clutch (unknown), new pistons, balanced crank, and other small parts ie. head bolts etc.
Now im far from a pro with engines, i just know enough to keep me out of trouble.
Opinions? And what can i do next to it????????????
Old Mar 14, 2005 | 08:18 PM
D200RST's Avatar
D200RST
also, i want reliability and would rather have 180bhp with reliability rather than 200bhp and no reliability. it also has a vernier pulley and rebuilt gearbox.
Old Mar 14, 2005 | 10:25 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
looks a pretty bay too
Old Mar 15, 2005 | 08:13 AM
rs nuts's Avatar
rs nuts
with the mods you have stated it is possible but do not run more than 16 psi if you want reliability in my opinion hope this helps
Old Mar 15, 2005 | 01:49 PM
james_birch's Avatar
james_birch
that will pass! i used to say that! now im tyring to strangle as much power out of it as i can!
Old Mar 15, 2005 | 02:39 PM
sufsRS's Avatar
sufsRS
itd be worth gettin a service done and deffo a timing belt, mek sure fuelling is right get boost dwn to bout 16psi and just look after it oh and get rid o the shitty dump valve
Old Mar 15, 2005 | 08:32 PM
D200RST's Avatar
D200RST
not a fan of dump valves at all but im not bothered too much. any other thoughts?? i kinda want somebody to gimme an idea of what i should be doing etc.
Old Mar 15, 2005 | 10:35 PM
AKRS1's Avatar
AKRS1
14psi should see 180bhp with those mods. Depends on who you get it tuned by. If its tuned proper proper than you should see around just over 180bhp with 14psi.
Old Mar 16, 2005 | 09:59 PM
D200RST's Avatar
D200RST
it seems to be peaking at 17psi......... suggestions??
Old Mar 16, 2005 | 10:12 PM
Ramonster's Avatar
Ramonster
I think it's sounds good... but that's allways when you buy something... Has he got receipts from all th stuff he's claiming to had??? Maybe you can do a testing on the rollers???
Good luck with it!!!
Old Mar 16, 2005 | 10:24 PM
Andy-R's Avatar
Andy-R
Looks good! A lot depends on whats been done to the turbo, no reason why 17psi cant be ran safely assuming its been set up correctly and assuming your intercooler is upto it.
Id seriously consider having it setup for peace of mind to ensure that there is plenty fuel.
Next steps if you want more power has to be Fueling Tweeked, possibly a larger intercooler, and possibly changes to the turbo itsself.....having things checked by a Pro whilst being setup will give you a clearer idea, of what you have and where to go next.
Enjoy it, and just steer clear from holding it flat out till you have had it checked out
Old Mar 20, 2005 | 11:13 AM
Dan's Avatar
Dan
Looks a smart engine bay mate, love the colour of the rocker cover looks awesome!
Good luck with getting it set-up!
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
`spotty
Sep 25, 2015 11:41 PM
Billy_RS
Sep 13, 2015 04:17 PM
