4x4 uprated gearbox?????
Right, just want to know whats about for about 3k, i know about dpe boxes but not sure on others.
Needs to be good for around 500bhp, rthinking of the box spadge had which was a dpe. Costs around £2500 i think.
So whats available then?
cheers
Benn
p.s I think ive asked this before but cant find it (well couldnt be bothered
cheers
Benn
wen i last looked, i think around £2750+ vat for the kit,
best ask bearnie gearboxman.
i run a r+d dog box, which is miles better on full go gear change, as use no clutch, but round town abit of a pig, and very noisie in and out of car.
or also try someone like A1 steve scott as he does get in 2nd hand units for around 1300-1500 for a good big tooth box.
Benn,
You have to realise that the prices of either the Quaife or Fixit kit (see my website under "transmission" ) are for the gear-kit ONLY and you would have to add £400 to £800 for fitting (depending on whether you had the gearkit as it comes or shot-peened and polished).
You're probably looking at the best part of £4k for either of the above items fitted in the car...
Benn, Ive got the 2nd/3rd straight cut gear option of the DPE box and its fooking pukka
If your spending £3k you should be able to pick up every gear straight cut, except 5th iirc...
Give Pete Doughty @ DPE a call on 01159 262 073 and tell him Steve Fletcher with the Esc Cos sent ya
If your spending £3k you should be able to pick up every gear straight cut, except 5th iirc...Give Pete Doughty @ DPE a call on 01159 262 073 and tell him Steve Fletcher with the Esc Cos sent ya
