Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Problem starting Ford Focus 56 plate
Old Mar 30, 2013 | 07:41 PM
swiftinio's Avatar
swiftinio
Exclamation Problem starting Ford Focus 56 plate
Hey guys,
Am not that technical savvy with cars and heard this was the place to find the pro's. Just recently got a Ford Focus Zetec 56 plate.
I've had no major problems with it up to press but today I tried to start the car and it wouldn't start.
When i turn on the ignition to stages 1 and 2, I get the usual lights which come up on the instrument dashboard (nothing which points to the problem from what I look in the owners handbook) and also interior lighting comes on aswell inside the car - however the interior lighting flickers and changes in brightness intensity like a dimmer switch is being used in the car.
When i then try and fully start the car (ignition stage 3) I get what can only be described as a ticking sound and the car doesn't sound.
My radio also displays a message like: "setup now: yes".
This coupled with the dimming interior lights which change in intensity I am thinking that this could be battery related. Have had the car for around 6 months and I haven't changed the battery since I got it. Nevertheless, i don't know if its fuse related, starter motor related or like I said, the battery. Its never happened before and I've tried with multiple different car keys aswell (didn't know if it was a car key immobiliser issue).
Would greatly appreciate any help whatsoever anyone!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
taylora1409
Aug 12, 2015 12:06 PM
Zoggon
Aug 10, 2015 10:39 AM
