p100 wiring looms and E/W
Old Mar 25, 2013 | 07:49 AM
cobyoshi's Avatar
cobyoshi
Default p100 wiring looms and E/W
Hi all
I am considering putting in electric windows in to my p100. I dont want to run a live of the battery etc unless i really have to. I wondered if anyone knew if i could simply get the door looms and plug in to the already existing p100 loom somewhere. I figured ford would have used the same loom as was in the td sierra only never plugged/put in the window looms when the looms went in to the td p100. But.. i could be wrong and end up ripping the dash out for nothing. Can anyone shed any light on this?
Old Mar 25, 2013 | 08:10 AM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Originally Posted by cobyoshi
Hi all
Change the loom from a saph Cossie / Ghia is the easiest a long with a pair of doors from any loaded sierra. Cut the rear interior loom out as you wont need it and splice in your rear lights, or you can cut the interior loom out and graph it in your p100.
I used a 4x4 saph cos loom. I have a mk1 ghia loom in the shed for sale you could cut the interior loom off of.
Good luck mate
Old Mar 27, 2013 | 02:03 AM
cobyoshi's Avatar
cobyoshi
Default Nightmare
I hate wiring just spent a lot of hours rewiring the rear lights I notice a crap job done before and battery died in the process I stuck it on charge and left it to return to another trying to move it and tried starting it.now the batt was very dead still ,it wouldnt start but I did notice the fuse blown in the charger. I replaced it but didn't have time to check if it screwed the wiring in the car or blew any fuses though I am thinking with the luck I am having it has done something.as I did notice tail lights not working,though I thought it maybe just cause the battery is really low. So can anyone shed any light on this will trying to start it with a charger on it blow the ecu,fuses,relays etc
Old Jan 20, 2014 | 07:15 PM
BON_300's Avatar
BON_300
Hi Guys
I want to fit Electric front windows , Electric door mirrors , Central lock , Fog lights and Head light wipers to my P100. Would I need a complete Sierra Cosworth wiring loom and fuse box ? I`m not decided on ABS yet but might consider it too.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
muz
Sep 30, 2015 08:29 AM
IainRS1700T
Sep 25, 2015 06:44 AM
