mk1 FRS stuff.
avail after easter as im moving house.
all FRS stuff. mk1.
driveshafts £100
hubs ( front) £50 each
ecus £100 each
mgmt loom £200
car loom £100
fuel tank no pump £25
decat £50
oxy sensors £25 pr
brembos and discs £ 200
front suspension legs with red lowering springs £80
rear suspension beam with blades £200
front lower arms £100 each
steering racks £ 50 each
pas set up £70
pedal box ( missing clutch rubber)£50
gear selector and cables with knob £90
handbrake £50
centre console £ 100
wings £200 each
bootlid £130 with spoiler
rear bumper mounting brackets £30
rear ARB £20
fron ARB £30
map sensor £25 x 2
door mouldings £50
turbo been rebuilt at somepoint by universal turbos. £300 no play
inlet complete ( no elbow) £100
coil pack £20
leads £15
radiator £50
interior plastics -
shelf supports
a b c pillar trims
cill trims
£50
boot carpet £20
all FRS stuff. mk1.
driveshafts £100
ecus £100 each
mgmt loom £200
car loom £100
decat £50
oxy sensors £25 pr
pas set up £70
handbrake £50
wings £200 each
rear ARB £20
fron ARB £30
map sensor £25 x 2
door mouldings £50
coil pack £20
leads £15
radiator £50
interior plastics -
shelf supports
a b c pillar trims
cill trims
£50
boot carpet £20
hi mate, missed this one.
here is a list of whats left.
wings
centre console
pedal box
hand brake
front crash bar and slam panel
2x ecus
turbo
drive shafts
hubs front and rear
rear beam
front x member
map sensor
inlet complete
decat
chargcooler pump
repaired charge cooler rad
samco blue boost hoses.
various plastics.
wings
centre console
pedal box
hand brake
2x ecus
turbo
drive shafts
hubs front and rear
rear beam
front x member
map sensor
inlet complete
decat
chargcooler pump
various plastics.
wowk
Mar 30, 2021 07:49 PM
