2wd Sapphire rear diff
Old Mar 22, 2013 | 07:04 PM
Stuart848's Avatar
Stuart848
2wd Sapphire Cosworth
Default 2wd Sapphire rear diff
Are 2wd sierra sapphire cosworth rear diffs all slippers?
Are the standard sierra open rear diffs interchangeable with no mods?
Simple test just to spin 1 wheels and see what way other wheel turns?
Old Apr 27, 2013 | 07:25 PM
opposite lock's Avatar
opposite lock
All cosworth 2wd diffs are LSD and unique being 7.5 inches wide. Couldnt say they can interchange i doubt it.
Old Apr 29, 2013 | 09:40 AM
booner999's Avatar
booner999
My escort has a sierra rear beam for the 7.5 diff
Old Apr 29, 2013 | 01:04 PM
martysmartie's Avatar
martysmartie
Assuming you have Escos, no as your current diff is 7".
You can do it, you just have to cut a bit of the diff off though, from what I learnt from Dojj in another thread the other day, supposedly cutting the top of the diff works as well?
Also the drive shafts are different, 2WD are bolt on, where as yours will be 'splined'.
Lesser models had the 7" open diff, although some do have LSD's, also there are a few DOHC models which had the 7.5".
Yes the easiest test is as you say.
Martin
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
rog
Aug 30, 2015 05:32 PM
xr4x4rs
Aug 6, 2015 09:03 PM
Old ford
Jul 31, 2015 06:50 AM
