2wd Sapphire rear diff
2wd Sapphire Cosworth
Are 2wd sierra sapphire cosworth rear diffs all slippers?
Are the standard sierra open rear diffs interchangeable with no mods?
Simple test just to spin 1 wheels and see what way other wheel turns?
Assuming you have Escos, no as your current diff is 7".
You can do it, you just have to cut a bit of the diff off though, from what I learnt from Dojj in another thread the other day, supposedly cutting the top of the diff works as well?
Also the drive shafts are different, 2WD are bolt on, where as yours will be 'splined'.
Lesser models had the 7" open diff, although some do have LSD's, also there are a few DOHC models which had the 7.5".
Yes the easiest test is as you say.
Martin
Martin
09-10-2015 07:38 PM
FlashRS
13
31-08-2015 06:02 PM
xr4x4rs
06-08-2015 09:03 PM
