Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
can i fit focus st xenons
Old Mar 20, 2013 | 08:50 PM
craigfocus's Avatar
craigfocus
Default can i fit focus st xenons
ive just seen some st standard xenon headlights with ballasts for sale and im tempted to get them but im not sure if they will work on a standard mk2 focus with it not having self levelling, has anyone fitted these in a non st or know someone who has?
dont want to buy them blind and waste my cash on them
Old Mar 20, 2013 | 09:18 PM
RichieST's Avatar
RichieST
I'm pretty sure the wiring plugs are different, the ST lights are bi-xenon, along with the normal high beam bulb they also have a little shade that drops down over the xenon bulb when you select main beam so it aims the beam higher. Not too sure if this is controlled within the headlight or seperately etc.
Old Mar 25, 2013 | 04:50 PM
For the mot you will need from headlight washer jets too.
Old Mar 25, 2013 | 05:41 PM
craigfocus's Avatar
craigfocus
from what ive found out if i have 10 wires on the plug that connects to the headlight will work fine, but im not sure about the levelling as st's are self levelling so i dont know if the level adjuster in my car will work, i will take them out for the mot but i dont want to fit them if i cant adjust them, its an expensive mistake if i buy them and they dont adjust.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
neil18
Mar 14, 2016 01:08 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
