Alhambra/Galaxy turbo problems... again!
Old Mar 19, 2013 | 11:34 AM
KregRS's Avatar
KregRS
Default Alhambra/Galaxy turbo problems... again!
Having just had a recon turbo fitted after killing the last one, I got the car back last Wednesday. All was fine, until last few days, seemed to come on boost later and later, but was running fine. Used the car earlier and it feels like there is no boost at all, foot flat to the floor, and nothing is happening, it just isn't picking up. Its not smoking, and seems to run fine apart from this, so any ideas what I should be looking for?
Old Mar 19, 2013 | 11:37 AM
Daniel-1986's Avatar
Daniel-1986
possibly a split boost pipe
Old Mar 19, 2013 | 01:09 PM
KregRS's Avatar
KregRS
Apparently its something do with the wastegate, something sticking, took a drive over to a mechanic and it cleared on the way. He stuck it on diagnostic and it came up with a charge pressure code.
Old Mar 19, 2013 | 01:16 PM
V6 Ste's Avatar
V6 Ste
Take it back to who ever fitted the recon unit would be my first port of call. Running it with a fault might only do more damage .
Old Mar 19, 2013 | 02:03 PM
wilky's Avatar
wilky
could be the vane pack sticking some time mr muscle oven cleaner does the trick
or aultrasonic clean the van's ,some time's vane's can get sticky the catch on the housing or
them self in the vane pack which mean you need a new one
Old Mar 20, 2013 | 10:57 PM
KregRS's Avatar
KregRS
Turned out it was a split pipe and sticky actuator arm.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
