BMW 3series diesels, where to buy a 320Dsport tourer common faults,
I'm ideally after a 320d sport tourer but can't find a decent enough one, so what are 318SE 320d like to live with, as I don't fancy a ratty sport version when a 320d SE is so much cheaper. What have you got or driven?
Clutch judder when hot if overheated before ie towing. Have the bushes on the front checked as often go. If it fails to start then fuel relay.
I had one for quite a while, it went well, handled well and did brilliant mpg
Right, thanks for that, I've heard swirl flaps on some d's need swapping out and I've seen a couple now on 250,000miles and still ride very well. Bottom arms and turbos, righto
