Escort XR3i->ZVH->Zetec T
Hi. My 1990 1,6 Escort project.
First rebuild from 1,6 EFI to 1,8 ZVH @ 2008a:
Magnex exhaust system, Flo-flex & Vibratechnics
Walbro fuel pump, FM intercooler, Oil Cooler
Oz wheels & ATE Powerdisc brakes, Rebuilded stock turbo
MS V2,2, injectors from Saab 9000 350cc/min@3bar, FSE Fpr
Yellow adjustable Koni shocks, RST trum brakes, Gearbox rebuild kit:
EFI head:
Few pictures from building quality, back these days
Result of all this i got 230ish bhp:
EFI head:
It was fun to drive, but i wanted some more and my friend wanted to buy my ZVH and gearbox. So i sold it and car stays 3y in garage and waits new engine.
From that first conversion i have change my points of view in engine building and overall project building.
New engine building started from Silvertop Zetec 2,0.
Spec list:
Head with supertech +1mm valves IN & EX, with BMW bronze valve guides. ARP studs + Cometic head gasket (don't have yet, must measure heads combustion chamber first, for correct gasket thickness)
Bottom 9,0:1:
Je Pistons, Pro Seal rings + Eagle rods. Mahle/Kolbensmith bearings +ARP`s.
Work in progress (engine block washed):
Parts:
For starters cleaning bolt holes:
Measurements check:
Oil sprays in, big end bearings installation with Liqui Moly special lubricant:
Crank in place and ARP studs stretched:
Piston ring gaps grinded for correct fitment:
First weekend, ~12h labour.
Time flies when you do things like they should be done.
Conrod ARP tightening forces also measured.
Next weekend work continued:
Pistons & rods assembled and rings installed:
Pistons in:
And rod big ends stretched:
My mate M-Tech, who stands behind all this, measuring (Me, Bomsch as Mr. Wilson behind the wheel):
Another 4h gone. Now we will wait valves from US, to arrive.
Another parts around the engine:
830cc Siemens Deka injectors
Custom IN/EX manifolds
Megasquirt 2 V3 with launches, flat shift and so on. (maybe will upgrade to MS-3.)
Tial 44 wastegate.
Holset HX35 "Super"
MTX-75 Mondeo/RS2000 gearbox swap with MFactory metal plated dif.
Spec list:
Bottom 9,0:1:
Parts:
Measurements check:
Pistons in:
Tial 44 wastegate.
Holset HX35 "Super"
