Mk1 frs stuttering under full boost
Old Mar 17, 2013 | 11:03 AM
Russ Payne's Avatar
Russ Payne
Default Mk1 frs stuttering under full boost
Hi everyone
Just bought a mk1 focus rs
Under full boost in 4th at about 4000rpm it's just holding back and hesitating like the turbo is cutting in and out, can't get it to do it all the time tho
Any ideas?
Cheers Russ
Old Mar 17, 2013 | 11:39 AM
fiesta23's Avatar
fiesta23
does the boost drop when it does this ? could be a knackered actuator
Old Mar 18, 2013 | 04:29 PM
Sticky.'s Avatar
Sticky.
It's the ECU, it's got the 4k stutter.
Nothing to worry about.
Old Mar 19, 2013 | 08:43 AM
Russ Payne's Avatar
Russ Payne
How is this resolved? With a remap?
Old Mar 19, 2013 | 09:58 AM
JamboRS's Avatar
JamboRS
focus rs 1672
wouldnt say thats the 4.5k AF fault mate,it would just have a blip not hesitate and stutter
more than likely you have an air leak or its ignition related
check all your hoses on back of inlet.
mines did this and it was leads so try borrow leads/plugs coilpack and see if it solves it
Old Mar 19, 2013 | 08:38 PM
moondustka's Avatar
moondustka
Boooost!
And if you just bought it - give it a full service regardless of the history. Then you know it's all been done. I'd be more dubious about garage service history than a private person with receipts for service items.
Old Mar 23, 2013 | 03:50 PM
STAFFY OWNER's Avatar
STAFFY OWNER
Has it got a Bluefin on it? I put some old rolling road graphs of my car on the RSOC (done before i bought it) and this had a dip at about 4500 RPM and Shep from Sabre suggested it was something to do with the Bluefin and said he had seen it on other Bluefin cars. A later graph with Bluefin removed showed the dip had disappeared.
Money and time permitting i'll be getting it to either Sabre in Bristol or Jamsport in Northampton for a remap at some point hopefully.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
