Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
HELP! Problem with Ford Fiesta 1.2cc Zetec engine
Old Mar 15, 2013 | 05:29 PM
Sten's Avatar
Sten
Question HELP! Problem with Ford Fiesta 1.2cc Zetec engine
I have a 1.2cc 52 plate Ford Fiesta with a zetec engine. It starts great, first time every time, my problem starts as soon as I start to drive. As I'm driving it judders/kangaroos down the road and doesn't stop until the engine warms up which is around 15 minutes into the journey. It's allot worse when the weathers cold and really bad when it's cold and wet. The only example I can think of to describe it is if you go back 20 years and cars had manual chokes, and if you didn't get the choke pulled out the right length then the car would stutter down the road until the choke was positioned correctly. So because the symptoms are similar to a choke related issue I was wondering if there might be a problem with the automatic choke? If it is, where are they positioned? Is it a big job to fix? or is it nothing to do with the choke? Somebody mentioned a cold release valve but after I Googled "cold release valve" problems, all of the results showed the cars not starting correctly, but mine starts without any problems. So I'm stumped and any help with my problem would be really appreciated. If I missed any information out and you need any more to help solve my problem then just ask, thanks.
Old Mar 15, 2013 | 05:42 PM
martysmartie's Avatar
martysmartie
Modern cars are fuel injected, therefore there is no choke, instead the fuel delivery is computed by the ECU on receipt of inputs from various sensors.
One of these is the CTS (Coolant Temperature Sensor) this as the name suggests informs the ECU of the temperature of the coolant, it therefore will then deliver a richer mixture for a cold start, for example, on your engine this will be between two of the spark plugs, and it actually measures the temperature of the head itself, opposed to the coolant.
Being these are electronic components they do go out of range after a while and give duff information, therefore the engine will run badly, it may be worth replacing this and if this is no good, scanning the car for fault codes, this can then isolate the problem to a particular sensor etc.
Martin
Old Mar 15, 2013 | 07:42 PM
Sten's Avatar
Sten
Talking
Martin
Thanks mate, that deffinately makes allot of sense. I'll look into that first thing in the morning
Old Mar 15, 2013 | 09:12 PM
Colin_P's Avatar
Colin_P
If the CTS doesn't work then coilpack and or ht leads.
Old Mar 17, 2013 | 06:47 PM
Coil pack very common on the zetec engines.Really easy to change.It will only take you 5 mins to swap over.
JoeyBoyden
Jan 4, 2024 02:36 PM
Blown Hell
Aug 5, 2015 07:22 AM
turbobill
Aug 1, 2015 08:55 PM
