Turbosmart Clearance Sale
We have a few Turbosmart items that we have had in stock for a while, so we are prepared to let them go at a discounted rate to clear the stock.
Ultra-Gate38 External Wastegate RRP £329.99 Sale £275.00
1 in stock
Part Numbers:
BLUE: TS-0501-1010
38mm external wastegate. Small and lightweight, the Ultra-Gate38 provides high-end features and build quality at an entry-level price.
APPLICATION: Suitable for all turbocharged vehicles with an external wastegate turbo system. Street and racing applications. Flanges suit 1.50” outside diameter pipe.
SUPPLIED WITH: 7 psi spring (fitted), valve seat, 2 x stainless steel gaskets, mounting bolts and 2 x 1/8 NPT vacuum fittings. Kit Builder Packs available to customer specifications.
Hyper-Gate45 External Wastegate £515.99 Sale@ £450.00
1 in stock
Part Numbers:
BLUE: TS-0504-1001
45mm external wastegate. Turbosmart’s new 45mm external wastegate offers class-leading flow path and temperature resistance in a compact and lightweight package.
APPLICATION: Suitable for all turbocharged vehicles with an external wastegate turbo system. Suits 1.75” outside diameter pipe. Fits all popular 44mm flanges.
SUPPLIED WITH: Supplied with a 7psi spring (fitted), inlet and outlet weld flanges and V-band clamps, valve seat and 2 x 1/8 NPT vacuum fittings. Kit Builder Packs available to customer specifications.
DUAL PORT RRP £289.99 sale@ £230.00
1 in stock
Part Numbers:
38mm outlet TS-0205-1072 Black
Four BOVs in one. The Dual Port can be configured as a Supersonic, Megasonic, Plumb Back or Dual Port! Features sequential ports for quiet operation on mild boost and full performance at full boost. With a a Quick-release V-Band clamp, tool-free adjustment and all the parts needed for conversions included it is Turbosmart's most versatile BOV.
APPLICATION: Suits medium sized turbocharger systems on 4 to 6 cylinder engines developing 200 to 600 HP.
SUPPLIED WITH Blanking Plug, Extra Trumpet, V-band clamp, 38mm aluminium weld-on inlet adapter
Kompact DUAL PORT – Universal Fit - 25mm RRP £159.99 Sale@ £140.00
2 in stock
Dual outlet-type BOV. Dual Port vents both to the atmosphere and back into the air intake. Ports with sequential timing allow quieter operation during normal driving, while getting all the benefits of a vent-to-atmosphere BOV under race conditions. Easily converted to a full atmospheric or full bypass unit by using supplied port blanking plug.
APPLICATION: Fits most cars using the factory BOSCH or DENSO bypass valves, also Subaru Legacy/Liberty 09-10.
Please call or PM Me for any more info.
1 in stock
Part Numbers:
BLUE: TS-0501-1010
1 in stock
Part Numbers:
BLUE: TS-0504-1001
1 in stock
Part Numbers:
2 in stock
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
Mr S1
20
Sep 27, 2015 04:06 PM
