mondeo tdci problem please help !
Old Mar 13, 2013 | 05:20 PM
ESCORT-NUT-2012's Avatar
ESCORT-NUT-2012
Default mondeo tdci problem please help !
story goes my stepdad got a mondeo 2.0 tdci 0n a 07 plate day after he got it it would start fine from cold but struggle once hot , anyway garage said that 2 of the injectors were at fault so sent three away to be reconditioned as the forth they could not get out as it was seized now the injectors have come back they put them in etc now it wont start at all and they now say the ecu is at fault and needs sending away????
Old Mar 13, 2013 | 05:35 PM
HeavyD's Avatar
HeavyD
MNR Vortx
The injectors will properly need to be re coded because of the reconditioning
Not 100% sure if this is causing the problem tho
Old Mar 13, 2013 | 05:39 PM
HeavyD's Avatar
HeavyD
MNR Vortx
Might be a silly question but have you bleed the injectors while someone cranks the engine over?
Old Mar 13, 2013 | 05:40 PM
russ rs's Avatar
russ rs
Sound like they not recoded
Old Mar 13, 2013 | 05:45 PM
ESCORT-NUT-2012
its a garage (not ford ) that are doing the work so not sure ?
Old Mar 13, 2013 | 05:46 PM
FlashRS's Avatar
FlashRS
Done one recently, you have to write down the code numbers on the injectors and then re install the codes into the ecu, other wise the ecu does not recignise them. [ sorry about poor spelling!!]
Old Mar 13, 2013 | 05:53 PM
ESCORT-NUT-2012
also will there be any probs due to only three being reconditioned ?
Old Mar 13, 2013 | 05:57 PM
HeavyD's Avatar
HeavyD
MNR Vortx
Found on Google that a SnapOn Solus Pro can recode the injectors if you can find a garage with one and the correct lead for the Mondeo
Old Mar 13, 2013 | 06:00 PM
ESCORT-NUT-2012
they have sent the ecu away !
Old Mar 13, 2013 | 06:39 PM
HeavyD's Avatar
HeavyD
MNR Vortx
Have they sent it away with the 4 injector numbers so it can be recoded?
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Yeh the solus can programme and sync the injectors I had to do it last week, find out if the put the injectors back to the same cylinder as disconnecting to get it reconditioned wouldn't reset the memory unless they replace the electrics on top, is the car still in the garage then
Old Mar 13, 2013 | 06:47 PM
ESCORT-NUT-2012
yea still in garage and they reckon the ecu has a fault!
Old Mar 13, 2013 | 07:09 PM
gingerturbo
Really it'll be gud to hear what they come up with, gud luck with the fix
Old Mar 14, 2013 | 08:31 PM
ESCORT-NUT-2012
apparently the ecu is knackered due to water damage and is uneconomical to repair so a new one is needed
Old Mar 14, 2013 | 08:38 PM
gingerturbo
Have ya got the readout for the ecu test, or is there any visable signs
Old Mar 14, 2013 | 09:21 PM
ESCORT-NUT-2012
they showed my stepdad a email from the company stating the above
Old Mar 14, 2013 | 09:25 PM
oriurbo's Avatar
oriurbo
Sounds abit suspect to me. Sounds like the garage didnt know what they was doing.
Old Mar 15, 2013 | 06:07 AM
gingerturbo
Snap I was thinking the same, eurocarparts can repair Ecus just like a like a load of company's for less than Ł100
Old Mar 15, 2013 | 09:47 AM
ESCORT-NUT-2012
apparently its too corroded inside to repair and a new one is Ł600 +, then needs programming by ford etc
Old Mar 15, 2013 | 06:44 PM
gingerturbo
Fair enough, how much do ford charge for a ecu and sync
Old Mar 15, 2013 | 07:56 PM
wulliegunn's Avatar
wulliegunn
knowing those fekkers it'll be extortionate
Old Mar 15, 2013 | 08:25 PM
HeavyD's Avatar
HeavyD
MNR Vortx
Why can't you get a second hand ecu from eBay for a 3rd of the price and then get Ford to reprogram that?
Old Mar 16, 2013 | 06:42 PM
wulliegunn's Avatar
wulliegunn
Last time I went to Dealers with a part from somewhere else & asked for help,I was shown the door."We dont fit other manufacturers parts unless we buy from them also"
Old Mar 19, 2013 | 08:30 PM
karl mcghee's Avatar
karl mcghee
Talking
Could do it yourself with this bit off kit
http://item.mobileweb.ebay.co.uk/vie...282&cmd=VIDESC
Old Mar 19, 2013 | 08:57 PM
wulliegunn's Avatar
wulliegunn
Default handy gadgets
ooooh now that i like the look of
Old Mar 19, 2013 | 09:01 PM
karl mcghee
It is a must have tool if you do cars (ford)
Rob Wells
Apr 18, 2023 12:19 AM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Brickhouse
Sep 20, 2015 11:47 AM
talon1
Sep 15, 2015 10:27 AM
marky_g
Sep 12, 2015 04:26 PM
