water pump help thanks
Old Mar 10, 2013 | 11:09 PM
matthewpickup's Avatar
matthewpickup
Default water pump help thanks
hi all , as above i plan on using the 4x4 cosworth water pump but is this the best one to use ? or is the 2wd one better ?
thanks for the info
Old Mar 10, 2013 | 11:19 PM
daz1968's Avatar
daz1968
The 4wd is a production version of the 500 pump and allows water to circulate when thermostat closed so in my opinion is a better setup
Old Mar 11, 2013 | 10:23 PM
matthewpickup
thanks for the info 4x4 it is
Old Mar 12, 2013 | 07:59 PM
Cossie-26's Avatar
Cossie-26
Im guessing the 4x4 pump fits straight on the 2wd 205 block ??
Old Mar 12, 2013 | 08:44 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Ive got the same 4x4 pump and stat housing
Old Mar 12, 2013 | 08:46 PM
DixieTheKid
Pick-up P100 Power!
Dont forgot your need a 2wd pulley.
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
