Turbo diesel help needed - PLEEEEEEASE!!!
Old Mar 9, 2013 | 08:17 PM
perry3188's Avatar
perry3188
Default Turbo diesel help needed - PLEEEEEEASE!!!
Can anyone tell me if an escort intercooled turbo diesel engine will run without the injection advance connected on the pump?
What I mean to say is... I know it will run but will it run well? Are there enough options of adjustment e.g max fuel, boost compensator and advance/retard timing to iron out any issues that may occur e.g knock?
Really need help on this one, I've trawled every post on every forum I can find, I've rang a diesel specialist I know and still no answer.
Any information or options you may have may help. Even if you know where there's an early pump for sale (apparently easier to find rocking horse $+!T)
Old Mar 9, 2013 | 09:11 PM
matthewpickup's Avatar
matthewpickup
i had the 1.8 td in the p100 non intercooler , imo i would be careful as the timing has to be spot on with these to run well , they can adjust on the injector pump pulley maybe help you a little i dont know tbh i would change it with all the same bits or just leave it as it could give you lots of trouble
Old Mar 9, 2013 | 09:29 PM
Carl td's Avatar
Carl td
Escort mk4 td van
Is that the black plug looking thing with 3/4 wores on it if so mine is disconected and runs fine
Old Mar 10, 2013 | 09:20 AM
perry3188's Avatar
perry3188
Yes on the top of the pump with 3 wires and looks like it can twist on sliders. Mine is black but in this image it is red. Is this definitely what you've got disconnected? If so have you had to adjust fuel/timing or do you have any starting problems, power losses at certain rpm/load?
Old Mar 10, 2013 | 09:56 AM
Carl td's Avatar
Carl td
Escort mk4 td van
Yes thats the one. Ye mine is disconected was like it when i bought my van it is a mk4 1.8d converted to a td. I dont have any starting problems pump is timed correctly etc but my max fuel has been turned up a bit but by disconecting that i wouldnt say that you would get diesel knock etc. my cold start isnt conected either and it still starts up fine. Hope this helps
Old Mar 10, 2013 | 10:19 AM
perry3188's Avatar
perry3188
Thanks very much for the info.
Just to clarify, you have yours disconnected and the pump turned up - you said if I disconnect it you think I will get knock. Do you mean if I don't turn the pump up? Do you get any knock?
Old Mar 10, 2013 | 11:24 AM
Carl td's Avatar
Carl td
Escort mk4 td van
No i mean it shouldnt make it knock by disconecting it. It should be fine i have no troubles with mine
Old Mar 10, 2013 | 03:06 PM
perry3188's Avatar
perry3188
Brilliant thanks very much for that you've put my mind well at ease now! I assume your engine is running completely mechanically now then with no ecu?
I'm putting the '99 intercooled engine into a '98 van but want to keep the same wiring loom, gearbox and subframe (from the van so literally just swap engines) so being able to run the engine without the ecu is my main concern.
Old Mar 10, 2013 | 03:16 PM
Carl td's Avatar
Carl td
Escort mk4 td van
Ye its not running an ecu jus completely manual an runs fine as it is so i would image you would be ok
Old Mar 10, 2013 | 03:23 PM
perry3188's Avatar
perry3188
Thanks very much
Old Mar 15, 2013 | 11:12 PM
Carl td's Avatar
Carl td
Escort mk4 td van
How did you get on
Old Mar 17, 2013 | 10:01 AM
perry3188's Avatar
perry3188
I haven't disconnected it yet. Just changed the belts and I'm messing about with the fueling to get the power up before I disconnect. Then I'll know I'm not too far away with it. Wish me luck!
muz
Aug 16, 2015 12:57 PM
druidgetafix
Aug 15, 2015 10:22 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
taylora1409
Aug 12, 2015 12:06 PM
col93saphcos
Aug 7, 2015 03:21 PM
