Vibratechincs 2wd gearbox mount
Old Mar 9, 2013 | 08:56 AM
cossie891's Avatar
cossie891
Default Vibratechincs 2wd gearbox mount
Has anyone got one fitted or got pics of how it all goes on
Old Mar 9, 2013 | 01:59 PM
BRAMMER's Avatar
BRAMMER
The mount just bolts to the standard 3dr cradle and on to the standard Ford mount that is attached to the T5 box.
I need to fit mine still but i asked Ade the other day and he sent me some pictures of his as i was wondering if i needed
Mounted to the box as standard
standard mount and uprated as you can see they both have the oblong indention for slotting and bolting up.
Old Mar 9, 2013 | 02:49 PM
cossie891's Avatar
cossie891
I have it bolted to the gearbox and cradle already it's just that it doesn't look right and it vibrates the car horrible now
Old Mar 9, 2013 | 03:39 PM
Ade500's Avatar
Ade500
Fixing Fords
Have you done the outer two bolts up to tight?
Old Mar 9, 2013 | 03:42 PM
cossie891's Avatar
cossie891
Possibly have mate as the washers with mine are smaller than the rubber I will get some bigger washers and try it again
Old Mar 9, 2013 | 03:50 PM
Ade500's Avatar
Ade500
Fixing Fords
The washers on the other side are small on mine they go against the cradle . I don't think they need to be very tight at all as the rubber is quite soft. The nyloc will stop it undoing .
TPM961
Jan 15, 2018 10:50 AM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
155lee
Oct 27, 2015 04:55 AM
