ESCORT T25 ECU 'COSY' Problem
Old Mar 8, 2013 | 09:14 PM
Cosworth Tester's Avatar
Cosworth Tester
Default ESCORT T25 ECU 'COSY' Problem
Can anyone help, Ive currently got a friends Esc Cos small turbo and it has a PTS piggy back chip plugged onto the EEC iv ecu but at 1.2 -1.3 bar of boost which it what it was set on it runs way too lean ( AFR 15:1 on boost past 4k rpm. I put a softer actuator on and set up about 0.8 bar of boost but it was still a bit lean. It has an uprated pump so fuel pressure is ok but its a bit strange, ive cleaned all the contacts up on the plug but no better.
With the help of a local tuning firm who does a lot of OE remapping and has mapped these eec iv's years ago we are trying to load the modified file he has to the chip but are struggling.
Has anyone got any modified piggy back chips or normal modified chips / ecu or any ideas?
Many Thanks in advance
Colin
Old Apr 27, 2013 | 07:43 PM
opposite lock's Avatar
opposite lock
All above my head i,m afraid but it sounds like you need to be in contact with either the guys who did the work or better still skip that and ask MSD . http://www.motorsport-developments.co.uk/stus.html
You should fill your boots here , scroll down to ST Escos common faults.
Old May 27, 2013 | 03:48 PM
Stu @ M Developments's Avatar
PassionFords Creator
Most modules ive seen produced for that engine are far too lean, including super chips and many other well known ones.
Old May 27, 2013 | 04:34 PM
MrC's Avatar
MrC
It's a shame this ecu can't be as versatile as the l8, I've heard these can only be mapped upto 300bhp and that's your lot, is there anything after market that will plug straight onto the loom for some serious power???
Old May 27, 2013 | 09:21 PM
I've had well in excess of 400 from it, but the customer needed to take his car away that we were using for development and sadly i think he moved onto other interests and we never saw it again.
Old May 27, 2013 | 09:30 PM
MrC's Avatar
MrC
Interesting so you have cracked the COSY eeciv???
I'm sure if you crack her wide open there will be much interest as most just convert to l8 or p8 for more power.
Old May 27, 2013 | 09:56 PM
Did it years ago mate, just had to sort out a MAF voltage limit but it just never got finished as there isn't enough interest in the conversion for us to buy a car to use.
Old May 27, 2013 | 10:02 PM
MrC's Avatar
MrC
so what if you get a customer who wants it??? How long would you need the car for and the obvious question would be would the price reflect on development on their car, ie whose going to pay for the extensive time sorting the niggly final touches, obviously there's going to be a price difference between you mapping a EECIV as to an L8??
Old May 27, 2013 | 10:19 PM
Customer would pay only for the parts used. Injectors, fuel pump etc. the mapping etc would be down to us. The problem is of course, there are absolutely no 100% guarantees of success.
Old May 27, 2013 | 10:42 PM
MrC's Avatar
MrC
So if it didn't work the customer would lay nothing??
Jesus no wonder everyone shy's away from doing them
I admire your enthusiasm stu, no doubt you'd have it fully cracked if you had the car for as long as you needed.
should be an intersting read should that day come
Old Jun 3, 2013 | 01:02 AM
opposite lock
There must be someone out there good for it.
Old Jun 3, 2013 | 10:07 PM
21turbojon's Avatar
21turbojon
Hi.
Many of small turbo cosworth chips are tuned for 4bar fuel pres. regulator.
I think it would be the problem.
Regards
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
