Mondeo Mk3 Sweeping Dials
Hi,
Recently left my car in for a general service and when I picked it up I noticed that upon turning the ignition on, the dials on the dash all sweep around to the max and come back down to the start again. Also, the trip computer's information is reset (temp in FH, miles in KM, average miles etc reset). The clock is also not working. The car is turning over fine, never had any hesitation with starting the car.
I had this problem before and simply replace the fuse for the clock and everything worked fine, but this time it is not solving it. Is their anything that would have been performed in a service that could cause this?
Thanks for any help.
Turn the ignition on
If the dials sweep you have had an interrupted power issue
If you then turn the ignition if and on again does it do it again?
Make sure you turn the ignition full off rather than just position one
mk3ste
Oct 17, 2021 10:09 AM
wowk
Mar 30, 2021 07:49 PM
Steve Escos
Oct 1, 2015 06:57 AM
