Running issues 4x4 sapphire
Old Mar 7, 2013 | 09:06 PM
chowfornow's Avatar
chowfornow
Default Running issues 4x4 sapphire
Hi all,
Can anybody help.
I've got a 4x4 sapphire cosworth that is stalling at random, tested all sensors etc, the fault is pointing at the ignition module ish, when its been tested running there is a break in power at the loom running into the module , the module is fine but can't understand what's causing this break in power, it can also be a nightmare to start because of the same problem. Any ideas?
Thanks
Old Mar 7, 2013 | 09:09 PM
jason_nike's Avatar
jason_nike
Have you checked the loom blocks in the engine bay by the bulkhead.
Known problem on the 4x4
Old Mar 7, 2013 | 09:11 PM
chowfornow's Avatar
chowfornow
They have been checked but defo worth another check, cheers mate
Old Mar 7, 2013 | 09:13 PM
martysmartie's Avatar
martysmartie
Is the break in the power not the 'switching' and so normal?
Martin
Old Mar 7, 2013 | 09:17 PM
chowfornow's Avatar
chowfornow
The pulsing coming from the module is fine then power just stops, then car cuts out, if the power comes back the car picks up again and runs till next time it breaks unless its stalled, then it can be a pain to start, it's wierd
jason_nike
Aug 18, 2019 10:53 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Chas
Sep 21, 2015 08:57 PM
Red_bull
Aug 9, 2015 08:34 AM
Old ford
Jul 31, 2015 06:50 AM
