Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
How to paint a plastic bumper?
Old Mar 6, 2013 | 04:58 PM
wowk's Avatar
wowk
Default How to paint a plastic bumper?
Hello,
I have a Escort van and yes i know you can pick primed bumpers off ebay for £40 but my friend is willing to do at his friends body shop. I've got to supply all the products though so what exactly will i need? I'm also spraying the back 1/4 bumpers up, so for free labour it ins't too bad
Cheers,
Wowk
Old Mar 6, 2013 | 06:34 PM
tonysierra4x4's Avatar
tonysierra4x4
basically needs to be spotless, apply plastic primer and the rest is the same as other paintwork. probably be someone along in a while to say something different. if your mates friend has a bodyshop he should know for sure.
Old Mar 6, 2013 | 06:51 PM
dean richardson's Avatar
dean richardson
Red scotch . Plastic primer . Normall primer . And some 600 wet and dry to rub the normall primer down . And then you will need your base coat and Laquar . Job done
Old Mar 6, 2013 | 06:59 PM
denis's Avatar
denis
Originally Posted by dean richardson
And then you will need your base coat and Lacquar . Job done
and thinners and hardener
Old Mar 6, 2013 | 07:03 PM
dean richardson
Sorry my bad forgot thinners and hardener maybe get some rocket in it while your on haha .. I havnt been in the body shop for a good couple of years now must be a bit rusty
Old Mar 6, 2013 | 07:06 PM
denis's Avatar
denis
rocket is useless
in work i da bumpers with 320-500 grit with a soft interface, degrease, coat of plasticizor, 2 coats of high build then bake
dry sand the primer with 500-1000 (depends on what colour the bumpers going) grit on a da with soft interface, blow off, degrease, panel wipe, basecoat, clearcoat, bake
boeb
Jan 9, 2020 05:11 AM
gambo08
Feb 4, 2016 10:49 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
rsguy
44
Sep 29, 2015 03:29 PM
