Uneven Tyre Wear
Have just noticed that on my Mk3 Mondeo I have uneven tyre wear, I had new tyres middle of last year and had the tracking done too, just removed the front wheels to changed the front brakes and noticed the passenger side tyre is already on the wear indicators
but only in the middle of the trye
the drivers side tyre still has loads of wear left on it
Anyone got any idea's has to why
Cheer's Brian
but only in the middle of the tryeAnyone got any idea's has to why
Cheer's Brian
If its gone in the middle of the tread then its had too much pressure in it. Like wise if its the two outer edges its down to too little pressure. This is part of the reason why you should periodically check your pressures.
[quote=phil_focus;6186920]If its gone in the middle of the tread then its had too much pressure in it. Like wise if its the two outer edges its down to too little pressure. This is part of the reason why you should periodically check your pressures.[/quote
+1
+1
The annoying ginger guy
That's probily ya answer, I'd say you got one of ya front wheels out of line and scrubbing the centre, cos there budgets there only a soft material so there wear faster, also are the tyres on alloys or steels as some budgets don't have a wall measurement mailing the tyre have a more rounded crown
