Ford Range This section is for other models in the Ford range.
Series 1 turbo clocks
Old Mar 5, 2013 | 08:25 PM
dav105e's Avatar
dav105e
Default Series 1 turbo clocks
Hi I have a base model 1.1 mk3 escort that I've fitted an rs2000 16v engine. My clocks are the basic ones with speedo and clock.i bought a set of series 1 clocks with rev counter. When I plug them in they don't work properly. Do I have to change the plugs on the car loom?
Old Jun 3, 2013 | 01:29 PM
Peterson007's Avatar
Peterson007
Nice dear, you have done a good stuff. I've done also the little bit same thing but there was little problem with mine. I checked this to some other but no solution. Anyhow, best of luck for your changes.
car racing suits
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
JPA
Sep 1, 2015 09:12 PM
