Quick yes no answer needed!
Mar 13, 2005 | 11:37 AM
Mar 13, 2005 | 11:40 AM
dont know, post it in general discussion
Mar 13, 2005 | 12:02 PM
identical
but...
the mk3 doors have the 2 plastic bits in them for the handles,s2 dont use them
i might have a couple of mk4 doors at home if you need some
Mar 13, 2005 | 12:14 PM
They are 99% the same. The inner release handle for the catch mounts different but you can cut a section out of your old door and weld it to your new door to make it fit...
Mar 13, 2005 | 01:30 PM
I am pretty sure you wont get the MK3 mirrors to fit the MK4 doors as well
Mar 13, 2005 | 01:52 PM
Quote:
They do fit....
Mar 13, 2005 | 02:17 PM
The hole for the door lock is larger in mk4 doors.
Mar 13, 2005 | 06:31 PM
yes the doors will go on.
However the inside mk3 door skin mounting plug holes may need drilling into the door as not all of them are there on most mk4 doors.
Mar 13, 2005 | 06:44 PM
Cheers guys but I think I better try and find a mk3 passenger door
matman
Sep 9, 2015 05:45 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
col93saphcos
Aug 7, 2015 03:21 PM
