Loads of revs
Old Mar 2, 2013 | 10:47 AM
Rob Virgo's Avatar
Rob Virgo
Default Loads of revs
Sorting out the project trackshed this morning,got it started last week but tidying a few jobs this morning.fitted exhaust and went to run up to temp for the first timeno throttle cable fitted yet
Revs are mad high and have done the following to try and sort
Changed blue temp sender back of head
Disconnected iscv
Disconnected tps
Checked for inlet manifold leaks
No change , if I blip the throttle it drops to idle for a sec then revs up again to prob 2/3k
Unknown chip but for greens/3bar etc
Base idle screw in throttle body,is there a set position as in screw out fully then in five turns or all in and five out....
Cheers for any help...
Old Mar 2, 2013 | 11:04 AM
martysmartie's Avatar
martysmartie
It's either got an air leak or the idle valve is jammed open!
Martin
Old Mar 2, 2013 | 11:43 AM
Ginge !'s Avatar
Ginge !
just finding my feet
Air leak or jamed throttle,, how high is revs ?
Spray carb cleaner so find it
Old Mar 2, 2013 | 01:42 PM
Rob Virgo's Avatar
Rob Virgo
Throttle is free , revs a out 2/3k I'd say , no rev counter yet
Wd40 to find air leak ???
Old Mar 2, 2013 | 02:37 PM
james kiely's Avatar
james kiely
could it be your tps rob?
Old Mar 2, 2013 | 03:13 PM
Rob Virgo's Avatar
Rob Virgo
Plugged that out to check james
Old Mar 2, 2013 | 07:15 PM
Rax's Avatar
Rax
As said,tps dirty throttle body/butterfly or air leak imo.
Old Mar 3, 2013 | 12:38 PM
Rob Virgo's Avatar
Rob Virgo
Just remembered when I had throttle body on bench and fitting the tps I read here about adjusting/setting a preload , might have stop set in the positive area of sweep , will try and release tps in situ but hard if I remember ...
Old Mar 3, 2013 | 03:50 PM
martysmartie
The TPS could affect idle BUT only with the information it is giving which then in controls the ISCV. The fact this is disconnected means there is an air leak or as I say the idle valve is open.
Yes WD40 can be used to determine the source of this, by liberally spraying around manifold etc with engine running if you then hear a change in idle, this is where the leak is.
Martin
Old Mar 3, 2013 | 04:51 PM
Rob Virgo's Avatar
Rob Virgo
Cheers mart
Old Mar 3, 2013 | 04:53 PM
Rob Virgo's Avatar
Rob Virgo
Is the closed fully position for idle adjustment all the way in as i presume
Old Mar 5, 2013 | 05:51 PM
martysmartie
The more you tighten the screw the lower the idle...
Martin
Old Mar 6, 2013 | 12:37 AM
Rob Virgo's Avatar
Rob Virgo
Two jobs first then , screw in adjust or fully and then release tps and set base zero position
Onto manifold gasket after that tho
tankybaby66
Feb 6, 2016 02:24 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
