Saphire problems
Mar 1, 2013 | 02:41 PM
Saphire problems
Hi guys I got a sierra saphire that shakes when you brake and has a drone noise more of a rumble from the back any ideas
I was thinking warped discs and dodgy diff perhaps any ideas guys
Mar 1, 2013 | 02:58 PM
warped discs and wheel bearing or diff
Mar 1, 2013 | 03:02 PM
That's what I was thinking mate how can I check the diff?
Mar 1, 2013 | 03:13 PM
Meant to say its only noisy when under load if I let of the throttle it's quiet
Mar 1, 2013 | 03:21 PM
From: Under the water.... .......in a nuclear submarine
Check the diff to beam bolts
Mar 1, 2013 | 03:33 PM
Anything else mate? What about bushes would they cause the noise?
Mar 1, 2013 | 11:56 PM
I've found that seized/rough top mount bearings gave a bad vibration under braking.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
