Rear beam poly bushes ? Steerig rack Q
Old Feb 28, 2013 | 10:36 PM
leedsrhinos126's Avatar
leedsrhinos126
Question Rear beam poly bushes ? Steerig rack Q
Anyone got these bushes
I bought these for about a tenner a few month back so at the weekend it's time to fit. Can someone remind me how to remove the old bushes please? Will the old bolts be long enough ?
Also i have a standard manual steering rack which is fine but the amount of steering lock to lock is rediculous so is there a manual quick rack avaliable?
Thanks for any reply's.
Old Mar 1, 2013 | 07:10 PM
leedsrhinos126
Anybody?
Old Mar 1, 2013 | 07:13 PM
Cossy Mike's Avatar
Cossy Mike
Press them out against the weight of the car with a big socket, if the beam is out on the floor I used a 3 legged puller and they came straight out....
New one's pop in easy if you grease them up proper (and watch your fingers! )
Old Mar 1, 2013 | 09:23 PM
mark r's Avatar
mark r
think quaife do a quicker gear set but your need someone to open rack up and fit new gears.try burton power think ive seen it there
Old Mar 2, 2013 | 08:36 PM
matthewpickup's Avatar
matthewpickup
to get the old bushes out i drilled into the rubber around it and gave it a little chap out and no problems fitting new ones as said , you can buy quick racks , or there is a geared part that can be welded into the steering colum and i would think dose the same thing as a quick rack but not as straight forward ie not bolt on
Old Mar 2, 2013 | 08:42 PM
leedsrhinos126
I had time to do the bushes tonight, such a simple easy job. I thought it would be pain in the arse but no.
Still cant find info on a quick rack.
Old Mar 2, 2013 | 08:52 PM
matthewpickup
i am sure burton do the quick racks but its not gearing it a whole new rack , guessing you have tryed there?
Old Mar 2, 2013 | 09:27 PM
leedsrhinos126
http://www.burtonpower.com/xl-manual...ge-xlr126.html
I only found this manual rack, Im gonna ring on Monday to see if this differs from the standard rack.
Old Mar 2, 2013 | 09:43 PM
matthewpickup
i have got all be it the burton 2012 catalog here and its a quaife quick rack sierra rhd , 2.8 turns , part no QUAQR6 , and its £124.95 in this book , its on page 143 but dont know if the page number will be the same on the new 2013 book
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
