ST 170 to Zetec Flywheel?
Old Feb 28, 2013 | 12:15 PM
Phil Walker's Avatar
Phil Walker
Default ST 170 to Zetec Flywheel?
Hi, my clutch has started to slip this week and i'm wondering if i buy a solid flywheel from a 2.0 or 1.8 zectec, will it fit using a st170 clutch?
Thanks
Old Feb 28, 2013 | 12:30 PM
Steve.L's Avatar
Steve.L
I fitted an 1.8 zetec flywheel with an older mondeo clutch
Im not sure the ST clutch has the correct holes
Old Feb 28, 2013 | 12:34 PM
Phil Walker
interesting, what mondeo clutch went in then?
Old Feb 28, 2013 | 12:36 PM
Steve.L's Avatar
Steve.L
Sorry mines in a rwd setup .Didnt notice what car your using
Old Mar 1, 2013 | 10:56 PM
shanel's Avatar
shanel
keep us posted on what you fit and how it goes mate my flywheel rattling time to do something similar to yourself!!
Old Mar 3, 2013 | 01:56 PM
Phil Walker
Not sure it's such a wise idea now I've been resarching it. Seems the Zetec ones almost fit but not quite. No one seems to have bitten the bullet and tried it as far as I can see. It's obviously safer to buy a conversion kit from these expensive places. If I could pick up a Zetec one for next to nothing I'd like to see how similar it is and if it would just need drilling or something. But an expensive experiment
Old Mar 4, 2013 | 09:15 AM
Phil Walker
Has anyone simply fitted a Zetec flywheel complete with a Zetec clutch to an st before? Surely it would simply bolt right on? Thrust bearing position will always remain central so can't see there being a problem
Old Mar 12, 2013 | 02:13 PM
Sp3no's Avatar
Sp3no
Wont Work
Old Mar 12, 2013 | 02:36 PM
caprizetec170's Avatar
caprizetec170
2 litre flywheel will bolt on no bother,clutch is same size but a different spline not sure if there same depth either
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
