RPMs jumping only when idle
Old Feb 27, 2013 | 10:16 AM
baltais13's Avatar
baltais13
Default RPMs jumping only when idle
Hello!
My car is an 88' Sierra 2.0 EFI lambda (101hp).
When car is idling (I mean engine running while in neutral or clutch disengaged) RPMs are jumping pretty roughly from about 400-1000RPMs. When I step a little bit on the gas, then engine is running very smooth. What could be the problem?
Is the idle air valve dirty (and where is it located in this exact engine)? Or air flow meter? But I think air flow meter was okay, because I opened it up and checked resistances for the main air valve and they were okay.
Thanks,
Toms from Riga, Latvia, Eastern Europe
Old Feb 27, 2013 | 10:39 AM
dojj's Avatar
dojj
Resident Wrestling Legend
it'll be the idle control valve
one the side of the inlet manifold, looks like a tube about 6 inches long with one side being a bit thicker than the other and with 2 wires going to it on a multi plug
will be held in place by 2 10mm bolts top and bottom
it will need cleaning at the very least by letting it soak in a bowl of petrol overnight, just don't get it into the electrical contacts but make sure it goes into the 2 holes and you let it sit for about 24 hours
you will need a new gasket when you refit it
new ones were about £50 last time i checked
Old Feb 27, 2013 | 10:40 AM
dojj's Avatar
dojj
and they are the same on the granada's and the later dohc sierra's
you may need to reset the base idle again after cleaning them, there is a way to do it but i can't remember now but it involved removing the throttle position sensor and undoing the throttle stops too
Old Feb 27, 2013 | 11:00 AM
baltais13's Avatar
baltais13
Thank You very much dojj for the detailed info
Old Feb 27, 2013 | 11:48 AM
dojj's Avatar
dojj
this may help
http://forum.fordsierraclub.co.uk/vi...le+speed+reset
Old Feb 27, 2013 | 06:08 PM
baltais13's Avatar
baltais13
fordsierraclub not helping, because registration sucks there
All my e-mails were identified as spam e-mails altough they were @gmail.com
Anyways if someone knows how to reset the base idle, then I would be very thankfull
Old Mar 15, 2013 | 09:14 PM
Cossy Mike's Avatar
Cossy Mike
Where from Dojj, I need one for mine, Thanks
Old Mar 16, 2013 | 07:44 AM
dojj's Avatar
dojj
I shall try and get the sierra club to sort something out fella
Also just realised you've got a lambda equipped car, in which case it may be something else in the system, but I can't recall them ever being fitted with cats over here so if your engine bay is not as described by me above, a picture would be helpful
I'll find out about where to get one from mike, but if its a Cossie one they are different
Old Mar 16, 2013 | 08:15 PM
Cossy Mike's Avatar
Cossy Mike
Thanks
Is this to good to be true?
http://www.ebay.co.uk/itm/1810003944...=p5197.c0.m619
Old Mar 16, 2013 | 09:29 PM
dojj's Avatar
dojj
if it was me it would be silly not to buy at that price, even if it didn't solve the problem it's not going to break the bank
Old Mar 16, 2013 | 10:18 PM
Cossy Mike's Avatar
Cossy Mike
Is it a Cossy one? I can't remember what mine looked like
Old Mar 17, 2013 | 11:14 AM
dojj's Avatar
dojj
the cossie ones are the short ones, which slot into the inlet manifold, and they are FUCKING TIGHT!!!!!!!!!!!!!!!!!!!!!!
might be worth asking as a seperate topic
Old Mar 17, 2013 | 07:10 PM
Cossy Mike's Avatar
Cossy Mike
Confirmed they are Cossy iscv's
cheap buy, thanks
Old Mar 24, 2013 | 12:53 PM
twobluedoors's Avatar
twobluedoors
Unfortunately, the FSOC forum doesn't allow registration from hotmail or gmail addresses as they were used by a lot of spammers once-upon-a-time.
If you're having trouble, please just drop us a line and let us know. We can't help with a problem if we don't know about it, seriously.
Chas
Oct 5, 2015 07:13 PM
fordrallycar
Sep 30, 2015 07:57 PM
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
