2002 st70 heater problem
Old Feb 26, 2013 | 04:55 PM
lousley1985's Avatar
lousley1985
Default 2002 st70 heater problem
Can some one tell if if the problem I have is with the heater fan or resistor, when I turn the heater on the fan tries to move but doesn't now I've had the fan out and it seems to spin ok when I do it manually but when u connect it and try it it rocks back and fourth and doesn't spin the whole way round
Old Feb 26, 2013 | 05:19 PM
RichieST's Avatar
RichieST
Motor brushes failed most likely. Easiest option would be just to get a new fan unit from a breakers.
Old Feb 26, 2013 | 05:55 PM
Greasenuts's Avatar
Greasenuts
I agree with Richie. The fact that it's trying to turn suggest the motor is faulty to me!
You could use a multi-meter to check the voltage to it.
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
