ST170 part help
Old Feb 26, 2013 | 02:46 PM
borinous's Avatar
borinous
Default ST170 part help
After investigating a suspected leaking washer bottle i have un-earthed some bodges done behind the front bumper.
Seems at some point in its life my ST170 has had a front end repair. Ive checked over all the chassis at the front and all seems present and correct so it must have only been a cosmetic repair.
Now during the repair or the accident the Foglight brackets must have been broken as currently the foglights are being held in place with Cable ties and cardboard!!!
So first quesiton is can i get replacement brackets or do they come with the foglights? Ford quoted me £115 for the foglight + bracket combo (thats just one side)
Next question is regarding a potential missing item. Should there be a undertray between the bumper and the subframe? as presently there is nothing
If yes there should be one is a common one used across all of the mk1/mk1.5 focus range?
Old Feb 28, 2013 | 01:49 PM
borinous's Avatar
borinous
Anyone Bump
Old Mar 3, 2013 | 06:26 PM
Sniffle's Avatar
Sniffle
4346353 - ST170 RH Fog Lamp
4346356 - ST170 LH Fog Lamp
They seem to come as a unit
Try Ford parts uk
L/H £78.68
R/H £86.64
£165.32 the pair (excludes VAT) probably works out just as expensive with VAT
http://www.fordpartsuk.com/shop/sear...tart=20&cat=57
Old Mar 4, 2013 | 05:53 AM
borinous's Avatar
borinous
Cheers mate was hoping to just get the brackets but it seems i will have to buy the whole units instead
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
